Siebel Field Service Guide > Scheduling Using Siebel Scheduler > Creating Constraint Sets for Schedules >
Defining Constraint Sets
Constraint sets provide the basic definition for a predefined set of constraints that a service region uses for running the Optimizer. You associate a constraint with a service region in the Service Region List view of the Administration - Scheduling screen. For more information, see Creating Service Regions.
To define a constraint set
  1. Navigate to the Administration - Scheduling screen, then the Constraint Sets view.
  2. Create a new constraint set record, and complete the field as appropriate.
  3. Scroll down to the Constraints list.
  4. Create a new constraint record, and select a predefined constraint from the Add Constraint dialog box that appears.
  5. Enter a start and end date for the constraint, if applicable.
  6. To view the service regions that are associated with the constraint set, click the Service Regions tab.
Siebel Field Service Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
