Siebel Forecasting Guide > API Driven Forecasting > Forecast 2000 - Forecast Service Business Service Method ArgumentsThis topic describes the arguments that are associated with the GenerateForecast and RollUpForecast methods. GenerateForecast Method ArgumentsThere following arguments are associated with the GenerateForecast method: GenerateForecast (Forecast Series Date Id, Forecast Series Id, Position Id) Forecast Series Date IDThis argument takes the row ID of the date for which the forecast is to be generated. Forecast Series IDThis argument takes the row ID of the forecast series for which the forecast is to be generated. Position IDThis argument takes the row ID of the position of the participant for whom the forecast is to be generated. RollUpForecast Method ArgumentsThere following arguments are associated with the RollUpForecast method: RollUpForecast (Forecast Id, Position Id) Forecast IDThis argument takes the row ID of the forecast record for which rollup needs to be done. Position IDThis argument takes the row ID of the position of the participant for whom the forecast is to be rolled up. |
| Siebel Forecasting Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
