| Siebel Forecasting Guide > Forecasting (End User) > About Forecast Adjustments > Unadjusting a Forecast
 After using auto-adjust or making an adjustment to another user's record, you can use unadjust. Unadjusting a forecast only applies to forecasts with details. To unadjust a forecast
Navigate to the Forecasts screen.
In the Forecasts list, drill down on the forecast to be updated.
In the Details view, select the record or records you want to unadjust.
Click the menu button, and then click Un-Adjust Selected Details.
