Siebel Forecasting Guide > Forecasting (End User) > API Driven ForecastingYou can generate forecasts through batch mode using the Forecast 2000 - Forecast Service, which is provided by default with your Siebel business application. To generate forecasts through batch mode, you must implement the functionality that is available with the Forecast 2000 - Forecast Service and decide, for example, when and how often to run the batch mode forecasting job. For more information about API driven forecasting, see API Driven Forecasting which describes the functionality available with the Forecast 2000 - Forecast Service. |
| Siebel Forecasting Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
