| Siebel Forecasting Guide > Forecasting (End User) >  Adding Forecast Details
 Occasionally, the forecast that is created does not include each of the revenue items that it needs to include. Additional revenue records can be added manually. The list of records that can be added is determined by the Associate Search Spec of the forecast series, see Creating Search Specifications for Forecast Series. To add forecast details
Navigate to the Forecasts screen.
In the Forecasts list, drill down on the forecast to which details will be added.
In the Details view, add a new record.
In the Add Revenue Items dialog box, select the appropriate revenue item and click OK.
NOTE:  Users can add many revenue items at the same time by holding down CTRL or SHIFT and selecting the appropriate items. Users can also run a query and select each of the returned records. |
