Siebel Forecasting Guide > Revenues > Adding Multiple or Recurring Revenues Using SmartScripts (End User)Users can add multiple or recurring revenues from any screen where the Revenues view is found, for example Opportunities, Accounts, Projects, Contacts, Products, Partners, and Agreements. Multiple or recurring revenues can be added using SmartScripts. SmartScripts are accessed by choosing Script from the menu button in the Revenues view. Revenues created using SmartScripts reside in the same spreadsheet record. NOTE: Users can add recurring revenues from any screen that has a Revenues view. The Opportunities screen is used in the following procedure as an example. To add multiple or recurring revenues using SmartScripts
NOTE: A substantial number of the Script's fields are not necessary for the user's specific needs; fields that are marked are required. In addition, the script has a built-in calculation function. The application calculates the correct end date, frequency, or period. If the Replace Existing Revenues check box in the Revenue Schedule Default Values screen is selected, the script function replaces only the items added or owned by the user. It does not replace account revenues associated with other positions. |
| Siebel Forecasting Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
