Siebel Forecasting Guide > Setting Up Forecasting > Creating a Forecast Series >
Adding a Custom Field for Aggregation
You can add a custom field, such as Global Business Unit or Fulfillment, for use in the Aggregation view. To do so, you must first add the custom fields as a column in the S_REVN table, add the field to the Revenue business component, and add appropriate columns to the appropriate applets. You must then add the field to the appropriate LOV (Type FCST_AGGR_FLD) so that it is available in the Administration - Forecast Aggregation view.
For more information about the relevant business components and adding custom fields to the forecasting process, see Forecasting User Properties.
To add a custom revenue field
  1. Start Siebel Tools.
  2. Select the S_REVN Table.
  3. Create a column for the custom field - for example, for the Global Business Unit field.
    Field
    Value
    Name
    X_GLOBAL_BUSINESS_UNIT
    User Name
    Global Business Unit Ext
    Physical Type
    Varchar
    Length
    15
  4. Click Apply/DDL to save the changes to the S_REVN table.
  5. Lock the Project Symbolic Strings.
    Click on Symbolic Strings and create a Symbolic String with the same names as used in the column in the S_REVN table. For example, for the Global Business Unit field.
    Field
    Value
    Name
    User Name
    Physical Type
    Varchar
    Length
    15
  6. Select the Revenue business component.
  7. Click Fields and create a new field, for example, Global Business Unit.
  8. Select Applets and query on the appropriate applet, for example, Opportunity Revenue Schedule List applet.
  9. Click Lists and create a new list column, for example, Global Business Unit.
  10. Select the applet to which you added the field, for example, Opportunity Revenue Schedule List applet.
  11. Right-click the applet and select Edit Web Layout.
  12. Select Mode: 2: Edit List.
  13. Select the custom field, for example, Global Business Unit, in the Columns/Controls template; drag it and drop it into Applets Web Template (Edit) - Layout.
  14. Save the changes and recompile the Siebel repository.
To add a field to an LOV, complete the steps in the following procedure.
To add a custom field to the aggregation LOV
  1. Navigate to Administration - Data screen, then List of Values view.
  2. Click New to create a new record, and then enter the list-of-values type FCST_AGGR_FLD in the Type field.
  3. Enter the name of the custom field in the Display Value field.
  4. Save the record.
Siebel Forecasting Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
