| Siebel Forecasting Guide > Setting Up Forecasting > Types of Forecast Series > Creating a Hybrid Forecast Series
 A hybrid forecast allows you to have My Revenues and My Team's Revenues visibility in the same Forecast series, therefore combining a rollup and departmental snapshot forecast.
The hybrid forecast allows for a forecast process to include both a rollup forecast and a departmental forecast in the same forecast series.
Use the hybrid forecast if one manager does not want or cannot have subordinates creating a formal forecast each period, yet another manager wants to have subordinates running a formal forecast rollup.
Do not use the hybrid forecast if both managers want either just a rollup or departmental forecast.
 To create a hybrid forecast series
Navigate to the Administration - Forecast screen, then the Forecast Administration view.
Create a forecast series.
For information, see Creating a Forecast Series.Click the Forecast Series Participants tab and add the appropriate users.
For information about adding participants, see Adding Forecast Series Participants.Once you have added a participant, choose their visibility from the Visibility drop-down list by selecting either My Revenues or My Team's Revenues.
NOTE:  For a forecast series where visibility is set to My Revenues - Indirect Sales, the Visibility column is not available from the Add Participants view. CAUTION:  Do not select My Team's Revenues for a manager that has included a participant as this results in double-counting. NOTE:  If you cannot see the Visibility field in the Forecast Series Participants list, check to see which columns are being displayed. |
