| Siebel Forecasting Guide > Setting Up Forecasting >  Deactivating Auto-Forecast
 By default, the system preference Forecast: Auto-Forecast is set to true. This means that if you are a manager, when you forecast, the application automatically creates forecasts for subordinates who are listed as participants of that series who have not already created their forecasts. You can disable this feature if you want. For more information about the Forecast: Auto-Forecast system preference, see Forecast: Auto-Forecast System Preference. To deactivate auto-forecast
Navigate to the Administration - Application screen, then the System Preferences view.
In the System Preferences list, select the Forecast: Auto-Forecast record.
Change the System Preference Value to FALSE.
Restart the server.
