| Siebel CRM Fundamentals Siebel Innovation Pack 2015 E24770-01  |
![]() Previous  |
![]() Next  |
View PDF |
In Table 8-2, operators are shown in uppercase; however, query strings are case-sensitive, and the operators do not have to be in uppercase.
When you perform a compound query, you must use parentheses to control the order in which the search for matching records is performed.
Table 8-2 Compound Query Operators
| Operator | Description | Example |
 AND, and  |
 Placed between values, returns only records for which all the given conditions are true.  |
 OR, or  |
 Placed between values, returns records for which at least one condition is true.  |
 NOT, not  |
 Placed before a value, returns only records that do not contain the value.  |
 Surrounds the values and operators that will be processed first, regardless of the default processing order.  |
 LIKE, like  |
 Placed before a value, returns records containing the value.  |
 Note: The LIKE operator is case sensitive. To find matches regardless of case, see Table 8-1.  |
