Implementing Siebel Business Applications on DB2 for z/OS > Customizing a Development Environment > Roadmap for Creating Custom Extensions to the Siebel Schema > Amending the Storage Control File for New Schema ObjectsIf you need to create new database objects as a result of changes made to the Siebel Schema in Siebel Tools, you must create a storage definition for the new objects in your storage control file. If you do not create storage control file definitions for new objects, the required objects are created using values derived from the Defaults object in the storage control file when you apply the schema extensions to the development database using Siebel Tools. This task is a step in Roadmap for Creating Custom Extensions to the Siebel Schema. NOTE: If you have different storage control files for your development environment and production environment, you must add the new object definitions to both storage control files. Use the following procedure to add new object definitions to a storage control file. To amend the storage control file for new schema objects
| Implementing Siebel Business Applications on DB2 for z/OS | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
