Implementing Siebel Business Applications on DB2 for z/OS > Customizing a Development Environment > Process of Applying Schema Extensions to the Target DatabaseAfter testing schema extensions that you created in the development environment, you can migrate the changes to the target user-acceptance or production database. To apply schema extensions to the target database, perform the following tasks:
This process is a step in Roadmap for Creating Custom Extensions to the Siebel Schema. |
Implementing Siebel Business Applications on DB2 for z/OS | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
