Implementing Siebel Business Applications on DB2 for z/OS > Preparing for Implementation on the DB2 Host > About Setting Up the DB2 Subsystem > Considerations in Choosing the Database CCSIDThe current Siebel release supports ASCII- and EBCDIC-based coded character set IDs (CCSIDs) for all versions of DB2 for z/OS, and Unicode character set IDs on all versions of DB2 for z/OS, New Function Mode and later releases. The database CCSID you use determines a number of factors, for example, the sort order used in list applets. Review Siebel Release Notes on My Oracle Support for information about known restrictions; for example, the following features are not supported on databases with EBCDIC code pages: You must run development databases with ASCII or Unicode code pages, because databases with EBCDIC code pages do not support the following procedures in a development environment upgrade:
You can use an ASCII-, an EBCDIC-, or a Unicode-based CCSID to create your Siebel Schema, but, if you mainly use single-byte character sets, it is recommended that you use ASCII or EBCDIC CCSIDs to minimize storage space requirements. Review the following recommendations:
You can partition table spaces on a database with either an ASCII, an EBCDIC or a Unicode code page, so that limit keys reflect the sort sequence difference between ASCII, EBCDIC and Unicode. For more information, see Configuring the Siebel Database Layout. About Setting the CCSIDConfigure the CCSIDs on the DB2 installation panel, DSNTIPF. The APPLICATION ENCODING field allows you to specify the default application encoding scheme. The value of the DEF ENCODING SCHEME field on the same panel determines whether the default format in which data is stored on DB2 is ASCII, EBCDIC, or Unicode. NOTE: Set the value of the MIXED DATA field on the DSNTIPF panel to NO for all supported languages except Japanese. |
| Implementing Siebel Business Applications on DB2 for z/OS | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
