Implementing Siebel Business Applications on DB2 for z/OS > Installing the Siebel Database on the DB2 Host > Preparing a Storage Control FileThis task is a step in Process of Performing a Custom Installation. When you select the standard Siebel Schema installation method, the Database Configuration Wizard creates a storage control file based on the information that you provide in response to prompts. When you select the custom installation method, you must first create the storage control file that is used as the basis of your Siebel Schema custom installation. You can choose from the following options:
| Implementing Siebel Business Applications on DB2 for z/OS | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
