Implementing Siebel Business Applications on DB2 for z/OS > Installing the Siebel Database on the DB2 Host > About the Siebel Log FilesThe Upgrade Wizard writes logs that provide detailed information on the installation and configuration processes you run, and they also list all errors. The Upgrade Wizard writes the logs for a process to one of the following directories by default: where NOTE: You can select a different log directory name from the Log Output Directory screen when you run the Database Configuration Wizard. The The output and state directories are automatically archived on subsequent runs of a process that completes successfully. (The names of subsequent log directories are appended with About the State Log FileEach installation and database configuration process consists of a series of steps, each of which must complete successfully. If the Upgrade Wizard cannot complete a step, it marks the step as incomplete in the state.log file and exits. You must correct the error and then run the Upgrade Wizard again. When you rerun the Upgrade Wizard, it refers to the state log and resumes at the incomplete step that contained the error. About Process Log FilesYou can identify errors you encounter during an upgrade by reviewing the process log files, named Upgwiz.log (Windows) or srvrupgwiz1.log (UNIX), in the output directory. The name of the log file increments for subsequent log files that are created if the Siebel Upgrade Wizard is run again for the same process. |
| Implementing Siebel Business Applications on DB2 for z/OS | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
