Implementing Siebel Business Applications on DB2 for z/OS > Configuring the Siebel Database Layout > About Siebel Objects > Table Objects in Storage Control FilesThe following example illustrates what the Table object looks like in the storage control file: [Object 8005] The Table object illustrated in this topic translates into the following DDL output: CREATE TABLE SIEBTO.S_ORG_EXT ( VAT_REGN_NUM VARCHAR(30), Siebel Business Applications include one template for each encoding scheme when partitioning is used and one template for each encoding scheme for nonpartitioning. Most tables use page-level locking by default, but a few use row-level locking. The following tables use row-level locking: The following tables use table-level locking: NOTE: LockSize is not defined on the table level but for the corresponding table space. |
| Implementing Siebel Business Applications on DB2 for z/OS | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
