Implementing Siebel Business Applications on DB2 for z/OS > Configuring the Siebel Database Layout > Using the Siebel Database Storage Configurator > Working with CLOBs Using the Database Storage ConfiguratorYour Siebel application is delivered with the objects needed to create character large objects (CLOBs). You can use these objects to create CLOBs at the table level only, to avoid excessive processing overhead. The following procedure describes how to activate a CLOB.
Implementing Siebel Business Applications on DB2 for z/OS | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
