Implementing Siebel Business Applications on DB2 for z/OS > About Siebel Table Partitioning > About Table Partitioning Methods > Partitioning for Even Data DistributionThis partitioning method involves partitioning a table using an additional partitioning column, PARTITION_COLUMN, designed specifically for Siebel partitioning with even data distribution. This column is populated with data using a BEFORE INSERT trigger option to generate the partitioning value for each row. Most Siebel tables are tied together by the ROW_ID column from a parent table. Columns with an _ID suffix are used to define a parent-child relationship, for example, OU_ID. These columns might seem to be good partitioning candidates because they support the DB2 access path but, in fact, these columns are poor candidates for partitioning because ROW_IDs are generated in sequential order. (An exception is if the values in a column with an _ID suffix identify groups of related records; in this case, the column might be a suitable partitioning key.) To resolve the limitation caused by the sequential order of ROW_ID, Siebel Business Applications provide a column, PARTITION_COLUMN, which is used only for partitioning purposes. It is a physical column defined in a storage control file, but it is not a part of the Siebel Repository. It is important that you continue to use the name PARTITION_COLUMN if the Siebel application is to recognize this column. You must also define this column as NOT NULL WITH DEFAULT. A DB2 BEFORE INSERT trigger is used to populate the PARTITION_COLUMN values; it is defined in the Siebel storage control file. This trigger generates a random number between 00 and 10 and uses it to populate PARTITION_COLUMN. The partition limit keys are also numbers between 01 and 10. Rows are assigned to each of the 10 partitions based on the value of PARTITION_COLUMN generated for the row. For example, if the number generated for PARTITION_COLUMN is 6, the row is assigned to the partition with a limit key value of 6. By using a trigger to populate the columns, you can partition tables that do not have good candidate columns for a partitioning key due to their data content. Using a trigger, you can still generate values that distribute the data well. The EIM tables and some of the prepartitioned base tables do not use PARTITION_COLUMN. For information on partitioning EIM tables, see EIM Tables and Partitioning. When partitioning a nonpartitioned Siebel table, or when customizing a prepartitioned table, you need to assess whether PARTITION_COLUMN is the most appropriate partitioning key for the specific table. To improve query performance, ensure the partitioning key you use keeps related records together within each partition. |
| Implementing Siebel Business Applications on DB2 for z/OS | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
