Implementing Siebel Business Applications on DB2 for z/OS > About Siebel Table Partitioning > Example of Partitioning the S_ADDR_ORG Table > Example of a Table Space DefinitionThe definition for Tablespace object H0401000 follows: [Object 3643] You can easily identify a partitioned table space by reviewing the Partitions option in the Tablespace object in the storage control file. If the Partitions option is greater than zero, then the table space is partitioned and requires additional objects, such as Tableparts (Tspart) and partition or index objects. The number of Tspart objects is equal to the number of partitions. |
| Implementing Siebel Business Applications on DB2 for z/OS | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
