Implementing Siebel Business Applications on DB2 for z/OS > About Siebel Table Partitioning > Example of Partitioning the S_ADDR_ORG Table > Example of a Partition DefinitionIf you use the table S_ADDR_ORG, the column OU_ID appears to be a good candidate for a partitioning key. However, OU_ID contains data in the Siebel row ID format and row IDs are generated in ascending order. Instead a trigger is used to generate a random number between 00 and 10 and this number is stored in a new physical PARTITION_COLUMN. This column is defined in the storage control file for S_ADDR_ORG. NOTE: If you have evenly sized table partitions, using PARTITION_COLUMN as the partitioning key provides query performance optimization. If you do not have evenly sized table partitions, a different partitioning column might be more effective in enhancing performance and scalability. For tables that use table-controlled partitioning, you must define two types of objects in the storage control file: PartitionBase and PartitionPart. These objects specify the partitioning key column and partition value ranges. An example definition for each is shown. NOTE: If you are defining a partitioning index, you must create IndexBase and IndexPart objects to specify the partitioning key and value ranges. PartitionBase DefinitionThe example for object 9401 contains a DB2 BEFORE INSERT trigger to populate PARTITION_COLUMN. This is always defined by the SpecialCol keyword in a PartitionBase section. The syntax for the trigger implements the column PARTITION_COLUMN to S_ADDR_ORG as [Object 9401] The performance overhead of using a trigger is measured as a percentage of the inserts. Performance overhead depends on several factors, including row length and the number of indexes in the table. Triggers that use the S_PARTY partitioned table space, 10 partitions, 14 columns, and 443 bytes with 8 indexes, have demonstrated a performance overhead of less than 1% for each insert. PartitionPart DefinitionIn the example for object 9401, the PartitionBase section defines ten (10) partitions. Therefore, it requires ten PartitionPart objects. These are illustrated in the example for objects 9402 through 9411: [Object 9402] Siebel Business Applications provide generic values for the partitioning keys. Review these LimitKey values in the PartitionPart object and change them to suit the special requirements of your implementation. NOTE: The sorting order for EBCDIC values is different from ASCII. Example of the DDL for a Partitioned TableThe storage control file definitions for the partitioned table in the previous example result in the following output DDL statements: CREATE TABLE CQ10L007.S_ADDR_ORG ( "ACTIVE_FLG" CHAR(1) DEFAULT 'Y' NOT NULL, The trigger name, PTH0401, is based on a number assigned to the S_ADDR_ORG table within the Siebel Repository. The S_ADDR_ORG table is defined in table space H0401504. The trigger name and the table space name are both based on the number assigned to the S_ADDR_ORG table and stored in the table Group Code in the Siebel Repository. The table is partitioned on the PARTITION_COLUMN column, which is populated by the trigger PTH0401. The index S_ADDR_ORG_U1 is defined with the CLUSTER parameter so it becomes the clustering index; that is, rows within each partition are clustered according to the key of S_ADDR_ORG_U1. Schedule routine REORGs of the table space and index space regularly to sustain clustering order. Running REORGs regularly accommodates insert activity and reclaims PCTFREE and FREEPAGE definitions. When you are defining key ranges, remember that EBCDIC sorting order differs to Unicode and ASCII sorting orders. Numeric characters precede alphabetical characters in ASCII and Unicode, but the opposite applies in EBCDIC. NOTE: For most processes, the Siebel Row ID is generated as a BASE 36 value that contains the alphabetical characters A through Z and the numeric characters zero through nine (0-9). The EIM process uses a suffix that contains numeric characters zero through nine, so take this into account in defining the key ranges. |
| Implementing Siebel Business Applications on DB2 for z/OS | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
