Implementing Siebel Business Applications on DB2 for z/OS > About Siebel Table Partitioning > Partitioning Strategies for Special Types of Tables > S_ESCL_REQ and S_ESCL_LOG TablesThe tables S_ESCL_REQ and S_ESCL_LOG, which are used by Assignment Manager and Siebel Business Process Designer, tend to grow very large. S_ESCL_REQ is processed based on the GROUP_ID, whereas S_ESCL_LOG is processed by RULE_ID. You can partition these tables in one of the following ways:
NOTE: If resource contention occurs because multiple groups are using the same partition, consider increasing the number of partitions when you create new groups and assign new group IDs; this allows for a more granular level of GROUP_ID assignments to a partition range. |
| Implementing Siebel Business Applications on DB2 for z/OS | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
