Implementing Siebel Business Applications on DB2 for z/OS > Preparing to Deploy Siebel Business Applications on DB2 for z/OS >
About File Path and Directory Naming Conventions
This guide uses the following file path and directory naming conventions to specify file locations:
SIEBEL_ROOT. This location is the main Siebel release installation directory. Enterprise Server components, such as the Gateway Name Server and the Siebel Servers, are installed into this directory. The default top-level installation directory is C:\siebel\8.1.1.0.0\ses (Windows) or /siebel/8.1.1.0.0/ses (UNIX).
NOTE: $SIEBEL_ROOT (no italics) represents the value of the SIEBEL_ROOT environment variable, which usually corresponds to a module-specific installation directory, for example, siebel/siebsrvr for the Siebel Server.
SIEBSRVR_ROOT. This location is the Siebel Server installation directory. By default, the Siebel Server is installed in C:\siebel\8.1.1.0.0\ses\siebsrvr (Windows) or /siebel/8.1.1.0.0/ses/siebsrvr (UNIX).
DBSRVR_ROOT. This location is the directory in which the Siebel Database Configuration Utilities are installed on the Siebel Server. By default, the Database Configuration Utilities are installed in C:\siebel\8.1.1.0.0\ses\dbsrvr (Windows) or /siebel/8.1.1.0.0/ses/dbsrvr (UNIX).
Use lowercase for all file names, directory names, path names, parameters, flags, and command-line commands, unless you are instructed otherwise.
