Implementing Siebel Business Applications on DB2 for z/OS > Migrating a Siebel Database to Unicode Format >
Viewing the Log File
During the Unicode migration process, a log file is generated that provides information on the current status of the migration jobs. You can review the log file to determine the status of a specific job using the following procedure.
To view the migration job log
  1. On the Siebel Unicode Migration Option Menu, select option 4. View Log Database Joblog, and press Enter.
    The Joblog Query panel is displayed (panel ID is SBLULOGP).
  2. Specify the number of jobs that you want to display on the screen at one time by entering a value in the Rows field, then select the type of jobs you want to display by entering one of the following option numbers, and pressing Enter:
    • Option 1. Lists all of the jobs that completed successfully.
    • Option 2. Lists all of the jobs that did not complete successfully.
    • Option 3. Lists the jobs that did not run.
    • Option 4. Lists all of the jobs in the job log.
      The log file is initially populated with data as part of the environment setup, and is updated as jobs are run to reflect the current status of the migration jobs.
Implementing Siebel Business Applications on DB2 for z/OS Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
