Implementing Siebel Business Applications on DB2 for z/OS > Migrating a Siebel Database to Unicode Format > Process of Preparing the z/OS Host Environment > Transferring Migration Upgrade Files from the Midtier to the z/OS HostWhen you run the Unicode Migration option of the Database Configuration Wizard, files are generated in the midtier output directory that you specified. You must now transfer these files from the midtier to the z/OS host where they can be executed. This task is a step in Process of Preparing the z/OS Host Environment. To transfer the Unicode migration files to the DB2 host
| Implementing Siebel Business Applications on DB2 for z/OS | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
