 Siebel Life Sciences Guide > Setting Up and Configuring Safety System Integration > Process of Setting Up Safety System Integration for Siebel Medical >
Configuring Java Message Service Parameters for Safety System Integration
This task describes how to configure Java Message Service parameters required for safety system integration. This task is a step in Process of Setting Up Safety System Integration for Siebel Medical. To configure Java Message Service parameters for safety system integration
- In the Siebel client, navigate to the Administration - Server Configuration screen, then the Enterprises view.
 - Select the Enterprise Server that you want to configure, and then click the Profile Configuration tab.
 - Create a new enterprise profile record and complete the necessary fields.
- Set the following parameters on the form that appears:
    Profile  |
    JMSParameters_SafetySystem  |
    Alias  |
    Subsystem Type  |
    JMSSubsys  |
 - Set the following parameters in the Profile Parameters list applet.
    ConnectionFactory  |
    jms/aia/AIA_SEBLDrugSafetyReportJMSQueueCF  |
    SendQueue  |
    jms/aia/AIA_SEBLDrugSafetyReportJMSQueue  |
    SendUsername  |
    Set the value to the Oracle WebLogic user name. NOTE:  The Oracle WebLogic user must have access to the JMS queue.
    SendPassword  |
    Set the value to the Oracle WebLogic user password. The password is visible in plain text until the profile is saved and refreshed.  |
 - Restart the Siebel Server.
