 Siebel Life Sciences Guide > Setting Up and Configuring Safety System Integration > Process of Setting Up Safety System Integration for Siebel Medical >
Activating Workflows for Safety System Integration
This task describes how to activate the workflows that are required for safety system integration. You can modify the workflows to suit your own business model, using Siebel Business Process Designer. For more information, see Siebel Business Process Framework: Workflow Guide. This task is a step in Process of Setting Up Safety System Integration for Siebel Medical. To activate workflows for safety system integration
- Navigate to the Administration - Business Process screen, then the Workflow Deployment view.
 - Query for and activate each of the following workflows:
- LS Medical Update Product Issue Inbound
 - LS Medical Product Issue Create Inbox Item Inbound
 - LS Medical Product Issue Validation Workflow
 - LS Medical Product Issue Send To Safety
 - LS Medical Product Issue Close
 - Verify that each activated workflow is added to the Active Workflow Processes view at the bottom of the screen.
