Siebel Life Sciences Guide > Using Personalized Content Delivery > Working with Messaging Plans >
Associating a Messaging Plan with an Objective
You can define multiple objectives for your call plan period. You can associate messaging plans with these objectives. When associating messaging plans, you must provide a segment code for each association. The segment code indicates which messaging plan to recommended for which segments of the targeted contacts. A single messaging plan can be associated with multiple objectives, and multiple messaging plans can be associated with a single objective. You can also have the same target segment code for multiple messaging plans. Specifying a Segment Code for a Target
The following procedure shows you how to specify a segment code for a target. To specify a segment code for a target
- Navigate to the Objectives screen, then the My Objectives view.
- In the Objectives list, select a record and drill down on the Objective field.
- Click the Target Contacts tab.
- In the Target Contacts list, select an existing target contact record or create a new target contact record and complete the necessary fields.
- For each target contact, specify a Segment field value.
For example High, Medium, or Low.
Associating a Messaging Plan With an Objective
The following procedure shows you how to associate a messaging plan with an objective. To associate a messaging plan with an objective
- Click the My Messaging Plans List tab.
- In the My Messaging Plan List, create a new messaging plan record to associate with the objective and complete the necessary fields.
- Select a messaging plan in the Name field.
This messaging plan will be associated with the objective.
- For each associated messaging plan, specify a Segment field value equal to the value that you specified for the target (for example, High, Medium, Low).
This action indicates which messaging plan to use with which segment of the target contacts.
When you create a new call on target contact, you can select the Objective for the call. When you click Detail in Call Detail View, PCD compares the segment code on the target to find the recommended messaging plans that are accessible to you. These messaging plans are displayed on the top in PCD Viewer. For more information about recommended messaging plans, see About Recommended Messaging Plans.Siebel Mobile Guide: Connected
