Siebel Object Interfaces Reference > About Object Interfaces and the Programming Environment > Siebel Object Interface Methods That You Can Use to Control Data and Objects > Methods That Control Navigation Flow of Siebel ApplicationsThe following object interface methods allow your configuration to control the navigation flow of a Siebel application: These object interface methods explicitly specify the view, applet, or control that Siebel CRM displays or makes active. The following items apply for these methods:
Siebel CRM stores the properties of a Siebel object in the Siebel repository file (SRF). You cannot use an object interface method in Siebel VB to modify these properties at run time. A business component is an example of a Siebel object. |
| Siebel Object Interfaces Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
