Siebel Object Interfaces Reference > About Object Interfaces and the Programming Environment > Object Interfaces You Can Use to Access Siebel Objects >
About the Siebel Java Data Bean Object Interface
The Siebel Java Data Bean is a set of Java libraries that use the J2SE Development Kit (JDK). It is similar to the interfaces that are available through COM Data Control. It allows you to do the following work:
  • Use an external application, external component, or Java applet to access Siebel objects without displaying the Siebel client.
  • Access a Siebel application to read and write data.
  • Incorporate the Java libraries in Java applications, applets, servlets, JSPs, or Enterprise Java Beans. You can add these items to your Java application.
For more information about:
  • Developer resources for Java technology, see the following:
    http://www.oracle.com/technetwork/java/index.html
  • Communication with an external application, see How an External Application Communicates with a Siebel Application.
  • Operating systems and JDKs that you can use, see Siebel System Requirements and Supported Platforms on Oracle Technology Network.
Siebel Object Interfaces Reference Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
