Siebel Object Interfaces Reference > About Object Interfaces and the Programming Environment > Siebel Object Interface Methods That You Can Use to Control Data and Objects > Methods That Locate ObjectsThis topic describes object interface methods that allow your configuration to locate an active instance of an object that resides in a Siebel application so that another method can use this object:
If a Siebel object interface can locate an object, then it can use or manipulate this object. You can use any of the following object interface methods in your configuration to locate an object: |
| Siebel Object Interfaces Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
