Siebel Order Management Guide > Integrating Order to Cash and Distributed Order Orchestration > Process of Integrating Order to Cash > Enabling Component Groups for Order to CashAdministrators must verify that the component groups for order creation are enabled on the Siebel Server. When you enable component groups, all of the required components in those groups are started on the server for transaction logging. For information about enabling component groups, see Siebel System Administration Guide. NOTE: In addition to the component groups listed in this procedure, administrators must activate the component groups for any Siebel business application that they are using. For example, if you are using Siebel High Technology/Industrial Manufacturing, then you must activate the component groups needed for that application. You must also turn asset-based ordering off for the components that you enable for order to cash or for distributed order orchestration. This task is a step in Process of Integrating Order to Cash. To enable component groups for order to cash
For more information about enabling components, see Siebel CTI Administration Guide |
| Siebel Order Management Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
