Siebel Order Management Guide > Product Data Service and Import Export API Reference > Product Data Services API Methods Reference >
GetFavorites Method
Get a list quote or order favorites using search specification. External
Syntax
Product Data Service.InvokeMethod("GetFavorites", Input Arguments,Output Arguments);
Arguments
Argument
Type
Description
Input Arguments
In
Hierarchy: SiebelMessage (Integration object PDS Template Interface)
Output Arguments
Out
Error Conditions
Error ID
Error Message Text
User Action/Resolution
IDS_ERR_ANIESALES_MISSING_SERVICE_NAME
The '%1' user property is not defined in business service '%2'.
Define user prop Data Sync Service (GetFavorites) in Product Selection Service.
SSAOMErrCannotCreateService
Unable to create the Business Service '%1
Check to see if the business service defined in user prop Data Sync Service (GetFavorites) in Product Selection Service is defined correctly.
Siebel Order Management Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
