Siebel Order Management Guide > Product Data Service and Import Export API Reference > Product Data Services API Methods Reference >
ExecuteSearch Method
Executes the search on products using the input search option, such as product class, class attributes, attribute constraints, pricing criteria, and so on. External.
Syntax
Product Data Service.InvokeMethod("ExceuteSearch", Input Arguments,Output Arguments);
Arguments
There are two types of search supported: SearchByProduct or SearchByClass. SearchOption is a required input to indicate the type of search performed.
Arguments for SearchByProduct
Type
Description
Input Arguments
In
SearchOption: SearchByProduct. This input argument is required.
IO: an instance of Integration Object PDS Product Interface. This input argument is required.
PricingMode: Y/N (calculates price or not). Optional. Default value: Y.
EligibilityMode: 0,1,2 (eligibility display mode. 0 do not run; 1 run; 2 run but only return eligible ones). Optional. Default value: 1.
ContextMode: SiebelContext or ExternalConext. Optional, but if not provided, will not run pricing and eligibility.
Context: an instance of Integration Object PDS Catalog Context. It either contains SiebelContext or ExternalContext. Optional only if ContextMode is not provided; otherwise, required.
PriceSearchExpression: price field search expression. For example: is greater than 100 and is less than 1000. Optional.
ProductSearchSpec: product business component search specification. For example: [Name] like "IBM*". Optional.
ResultSize: number of products returned. Optional. Default Value 30.
Output Arguments
Out
Hierarchy: SiebelMessage (Integration object PDS Product Interface)
Arguments for SearchByClass
Type
Description
Input Arguments
In
SearchOption: SearchByClass. This input argument is required.
IO: an instance of Integration Object PDS Product Class Attributes Interface. This input argument is required. The user must specify class id, attribute id, and attribute value in attribute LOV value structure (array with 1 element for either freeform or LOV type attribute).
EligibilityMode: 0,1,2 (eligibility display mode. 0 do not run; 1 run; 2 run but only return eligible products). Optional. Default value is 1.
ContextMode: SiebelContext or ExternalConext. Optional, but if it is not provided, it will not run pricing and eligibility.
Output Arguments
Out
Properties of Input Arguments
Property
Type
Value
Description
ContextMode
String
SiebelContext, ExternalContext
SiebelContext: Using existing Quote/Order Information in Siebel Database. In this case, the API constructs the Context using the provided row_id
ExternalContext: External Call will provide the context information, API will pass them directly to the Pricing and Eligibility Process.
ResultSize
Number
For example, 30
The number of products that would be retrieved from the query result
Context
Hierarchy: SiebelMessage (Integration object PDS Catalog Context)
See the following examples.
None
Integration Object
SiebelMessage
None
Example of Input Arguments
PropertySet@0012C82C p#7 c#3 type="" vt=0 value=""
p["EligibilityMode"] = "1";
p["ProductSearchSpec"] = "";
p["PriceSearchExpression"] = "";
p["ContextMode"] = "SiebelContext";
p["ResultSize"] = "";
p["PricingMode"] = "Y";
p["SearchOption"] = "SearchByClass";
c[0] PropertySet@0A7AEFC0 p#4 c#1 type="Context" vt=0 value=""
p["MessageId"] = "";
p["IntObjectName"] = "PDS Catalog Context";
p["MessageType"] = "Integration Object";
p["IntObjectFormat"] = "Siebel Hierarchical";
c[0] PropertySet@0A778688 p#0 c#1 type="ListOfPDS Catalog Context" vt=0 value=""
c[0] PropertySet@0A7F7CE0 p#0 c#1 type="Context" vt=0 value=""
c[0] PropertySet@0AAD12D8 p#0 c#1 type="ListOfSiebel Context" vt=0 value=""
c[0] PropertySet@0AA29A88 p#4 c#0 type="Siebel Context" vt=0 value=""
p["BusObjName"] = "Quote";
p["ContextRowId"] = "1-10MLH";
p["SignalMode"] = "Quote";
p["BusCompName"] = "Quote";
c[1] PropertySet@0AA524A0 p#4 c#1 type="ClassAttributes" vt=0 value=""
p["IntObjectName"] = "PDS Product Class Attributes Interface";
c[0] PropertySet@0AACF400 p#0 c#1 type="ListOfPDS Product Class Attributes Interface" vt=0 value=""
c[0] PropertySet@0AA92A18 p#1 c#1 type="ISS PS Direct Subclass" vt=0 value=""
p["Class Id"] = "99-27K1T";
c[0] PropertySet@0AA53858 p#0 c#1 type="ListOfISS Class Attribute" vt=0 value=""
c[0] PropertySet@0A9B38B8 p#2 c#0 type="ISS Class Attribute" vt=0 value=""
p["Value"] = "Professional";
p["Attribute Id"] = "OM_Edition";
c[2] PropertySet@054B87F0 p#4 c#1 type="SiebelMessage" vt=0 value=""
p["IntObjectName"] = "PDS Product Interface";
c[0] PropertySet@00C8E8F8 p#0 c#1 type="ListOfPDS Product Interface" vt=0 value=""
c[0] PropertySet@0A798FF8 p#0 c#0 type="Product" vt=0 value=""
Example of Output Arguments
PropertySet@0012CCB8 p#0 c#1 type="" vt=0 value=""
c[0] PropertySet@02C806E0 p#4 c#1 type="SiebelMessage" vt=0 value=""
c[0] PropertySet@02B9FF00 p#0 c#2 type="ListOfPDS Product Interface" vt=0 value=""
c[0] PropertySet@0B97D3F8 p#24 c#0 type="Product" vt=3 value="99-27KMW"
p["Product Def Type Code"] = "Customizable";
p["Reference Price"] = "";
p["Vendor Integration Id"] = "";
p["Id"] = "99-27KMW";
p["Eligibility Reason"] = "";
p["Pre Pick"] = "N";
p["Product Id"] = "99-27KMW";
p["Part #"] = "";
p["Eligibility Status"] = "";
p["Parent Item Id"] = "";
p["Inclusive Eligibility Flag"] = "N";
p["Integration Id"] = "";
p["Net Price"] = "";
p["Effective To"] = "";
p["List Price"] = "";
p["Product Configuration Model Id"] = "99-27KMW";
p["Product Line Id"] = "No Match Row Id";
p["Effective From"] = "";
p["List Price Type Code"] = "STANDARD";
p["Product Type Code"] = "Product";
p["Quantity"] = "1";
p["Name"] = "OM_Windows NT";
p["Price List Id"] = "99-27LE5";
c[1] PropertySet@0B824EB8 p#24 c#0 type="Product" vt=3 value="99-27KN1"
p["Product Def Type Code"] = "None";
p["Id"] = "99-27KN1";
p["Product Id"] = "99-27KN1";
p["Part #"] = "";
p["Product Configuration Model Id"] = "99-27KN1";
p["Name"] = "OM_Windows XP";
Error Conditions
Error Message
Description
The 'Data Sync Service: ExecuteSearch' user property is not defined in business service 'PDS Product Data Service
The specified user property can not be found on the business service, which must have value PDS Product by default.
Cannot get property set 1%.
The required property set input 1% is not provided.
Unable to locate record with row id as '%1' in '%2
The specified row_id 1% in BC 2% could not be found.
Unable to create the Business Service PDS Product
Can not initiate the business service.
Siebel Order Management Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
