Siebel Order Management Guide > Product Data Service and Import Export API Reference > Product Data Services API Methods Reference > DeleteOrder MethodDeletes the order that matches the input. SyntaxProduct Data Service.InvokeMethod("DeleteOrder", Input Arguments,Output Arguments); ArgumentsExample of Input ArgumentsPropertySet@0012D384 p#0 c#1 type="" vt=0 value="" c[0] PropertySet@0A6E4FE8 p#4 c#1 type="SiebelMessage" vt=0 value="" p["MessageType"] = "Integration Object"; p["IntObjectName"] = "PDS Order"; p["IntObjectFormat"] = "Siebel Hierarchical"; c[0] PropertySet@0ACADCC0 p#0 c#1 type="ListOfPDS Order" vt=0 value="" c[0] PropertySet@0A903FE8 p#17 c#1 type="Header" vt=0 value="" p["Order Type"] = "Service Order"; p["Updated"] = "02/11/2005 13:54:39"; p["Order Number"] = "PDS Order Item Test"; p["Created"] = "02/11/2005 13:54:39"; c[0] PropertySet@0A900550 p#0 c#1 type="ListOfLine Item" vt=0 value="" c[0] PropertySet@0AB61530 p#62 c#1 type="Line Item" vt=0 value="" p["Cfg State Code"] = "New Item"; p["Volume Discount Item Id"] = ""; p["Exclude Pricing Flag"] = "N"; p["Extended Quantity Requested"] = "1"; p["Asset Integration Id"] = "42-50SHW"; p["Volume Discount Item"] = ""; p["Original List Price"] = ""; p["Updated"] = "02/11/2005 13:56:09"; p["Inclusive Eligibility Flag"] = "N"; p["Integration Id"] = "42-50SHW"; p["Prod Prom Instance Id"] = ""; p["Discount Source"] = "Manual"; p["Product Line Id"] = "No Match Row Id"; p["Created"] = "02/11/2005 13:54:50"; p["Due Date"] = "02/12/2005 00:00:00"; p["Prod Prom Source Id"] = ""; p["Volume Upsell Message"] = ""; p["Configuration Model Id"] = "42-50S1M"; p["Volume Upsell Item Id"] = ""; c[0] PropertySet@0A92EE38 p#0 c#0 type="ListOfXA" vt=0 value="" Example of Output ArgumentsPropertySet@0012DA78 p#0 c#1 type="" vt=0 value="" c[0] PropertySet@0AB9F028 p#4 c#1 type="SiebelMessage" vt=0 value="" p["IntObjectName"] = "PDS Order"; p["MessageType"] = "Integration Object"; p["IntObjectFormat"] = "Siebel Hierarchical"; c[0] PropertySet@0AC32B10 p#0 c#1 type="ListOfPDS Order" vt=0 value="" c[0] PropertySet@0A63EB20 p#0 c#0 type="Header" vt=0 value="" Error ConditionsThis method calls the help method described in DeleteQuote Method. |
| Siebel Order Management Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
