Siebel Order Management Guide > Using Asset-Based Ordering > Submitting an Order Using Asset-Based OrderingEmployee end users who are using asset-based ordering can use the following procedure to submit an order. NOTE: The following procedure shows how to submit an order for an asset owned by an account. You can also submit an order for an asset owned by a contact using a similar procedure, but navigating to the Contacts screen, and then the Contact Summary view.
Siebel Order Management Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
