Siebel Order Management Guide > Using Asset-Based Ordering >
Creating a Quote Using Asset-Based Ordering
End users can use the following procedure to create a quote for an existing customer purchasing a new service or product.
You can create a quote that is based on the assets of either an account or of a contact. This procedure shows how to create a quote for an account. Use a similar procedure to create a quote for a contact, but begin by navigating to the Contact screen, Contacts List view.
When you use this procedure, the account type determines whether a quote or order is created. If the account type is Residential, then quotes are not created and all modifications of the service profile create an order directly. For all other account types, a quote is created.
For contact-based ABO, the user creates orders directly and does not create quotes.
NOTE:  The following procedure shows how to create a quote for an asset owned by an account. You can also create a quote for an asset owned by a contact using a similar procedure, but navigating to the Contacts screen, and then the Contact Summary view.
To create a quote
  1. Navigate to the Accounts screen, and then the Accounts List view.
  2. In the Accounts list, click the name of the appropriate account.
  3. Click the Account Summary view tab.
  4. In the Installed Asset list, click New.
    The Quote form and Line Item list appear.
    NOTE:  If there is already an active quote for this account, then it is shown. If there is not already an active quote, then a blank new quote appears.
    In the Quote form, the Status field displays In Progress and the Quote # field displays a unique number generated by the application. The Quote Name field also displays this unique number, which you may change to a quote name.
  5. In the Line Items list, click Add Items.
  6. In the Pick Products dialog box, select the items that the customer wants, and click OK.
    The Action field for the line items you added displays Add. For products and services that are customizable, the Customize button is available.
  7. To customize an item, select it in the Line Items list and click Customize.
    A Configurator session starts and displays selection pages.
  8. Make the selections that the customer wants, and click Done.
    The Quote Line Items list appears with the quote.
    Some fields in the Line Items list, and the Totals form below it, are described in the following table:
    Field
    Comments
    Item Net Price
    The price of the line item after discounts from pricing rules, volume discounts, or manual discounts. (Read-only)
    Extended Price
    Quantity times the start price.
    Net Discount%
    The percentage of the start price that the discount equals. If a discount was entered in either Discount Amount or Discount Price, then this percentage is calculated using the discount entered and the start price. (Read-only)
    Extended Net Price
    Quantity times the unit net price. (Read-only)
    Discount Amount
    The amount to be discounted for each unit, as a dollar figure.
    Discount%
    The discount amount relative to the unit price, shown as a percentage.
    Discount Price
    The total amount to be charged for the item, for each unit.
    Non-Discount Extended Price
    The extended start price.
    Sub-Total
    The sum of all items in a product with components with a one-time price type.
    MRC Subtotal
    Monthly recurring charge subtotal. The sum of all items in a product with components that are charged by the month.
    Action
    Action required for processing a modify order. Choices are add, update, delete, suspend, resume, or - (dash). A dash means the item was not changed, though the associated child line items may change.
    Agreement Name
    Agreement under which the quote line item was made.
    Adjustment MRC
    Total adjustments for monthly recurring charges.
    Adjustment NRC
    Total adjustments for non-recurring charges.
    Item Total MRC
    Total charges for monthly recurring charges.
    Item Total NRC
    Total charges for non-recurring charges.
    Net Total MRC
    Net total for monthly recurring charges.
    Net Total NRC
    Net total for non-recurring charges.
    Total Item Discount MRC
    Total discounts for monthly recurring charges.
    Total Item Discount NRC
    Total discounts for non-recurring charges.
Siebel Order Management Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
