Siebel Order Management Guide > Workflow and Method Reference for Order Management Interface > Order Management Interface Methods Reference >
CreateNewApprovalTasks Method
This method creates a new approval task for a quote, order, or agreement. This method is part of ISS Approval Business Service.
Arguments
Input Argument
Type
Property Name
Comments
Approval Level Context
Process Property
Added to accommodate Self-Service applications. Contains the Account ID.
Approval Item ID
Process Property
Object Id
Row ID of the item that needs to be approved; for example, Quote ID, Order ID, and so on.
Approval Level Name
Process Property
Approval Level Name
Name of the Approval Item that is defined in the Administration - Application screen, Approval Admin view.
Inbox Type
Process Property
Inbox Type
Inbox Type that is defined in the Administration Inbox screen; for example, Quote, Sales Order, Agreement, and so on.
Line Item #
Process Property
Line Item #
Not currently used.
Line Item Name
Process Property
Line Item Name
Not currently used.
Requesting Buscomp
Process Property
Requesting Buscomp
Business component that triggers the approval procedure. Used for dynamic drilldown (Quote, Order Entry - Orders, Service Agreement, and so on).
Return Message
Process Property
Return Message
Return Message defined in the Rule Set in the Administration - Data Validation screen, Rule Set view.
SendEmail
Process Property
SendEmail
Determines whether to send an email to the approver. Values are TRUE, FALSE.
Siebel Order Management Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
