Siebel Order Management Guide > Creating a Quote or Sales Order > Common Tasks for Creating Quotes and Sales Orders > Calculating TaxesIf your Siebel Business Application has been integrated with third-party tax software from Taxware, then an end user can click the Calculate Taxes button to determine taxes and insert them in a quote or order. If your application is not integrated with third-party tax software, then an end user can enter a tax rate manually. For products with components, taxes may be calculated either on the individual components, or on the extended price for the product with components. The method used is determined through the Product Administration screen. NOTE: If you change items or prices in the quote or order, then be sure to recalculate the taxes when you are finished. This task is part of the Common Tasks for Creating Quotes and Sales Orders. To calculate taxes by entering a tax rate manually
Use the following procedure to calculate taxes using third-party tax software. To calculate taxes using third-party tax software
| Siebel Order Management Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
