Siebel Order Management Guide > Creating a Quote or Sales Order > Process of Enabling the Automatic Configuration of Customizable Products >
Setting Up Siebel Tools for the Automatic Configuration of Customizable Products
Use the following procedure to set up Siebel Tools to support the automatic configuration of customizable products that are based on a promotion definition. This procedure is a step in Process of Enabling the Automatic Configuration of Customizable Products. To set up Siebel Tools to support the automatic configuration of customizable products
- Start Siebel Tools and connect to the server data source.
- Navigate to Projects in the Object Explorer and:
- Lock the following repository projects:
- ISS Promotion Admin
- ISS Promotion Integration
- ISS Promotion Workflow
- SIS OM Base Architecture
- Symbolic Strings
- UMSUI
- Create a new repository project where Name is Headless Configuration.
- Create the required symbolic strings:
- Navigate to Symbolic Strings in the Object Explorer.
- To display this object type (if not already displayed): Click View, select Options, go to the Object Explorer tab, and then select the checkbox next to Symbolic Strings.
- Create three new records, with the following values:
- Name is SBL_PROM_AUTOMATCH
Current String Value is Promotion Automatch Translate Flag is TRUE Type is Conversion Project is Symbolic String
- Name is SBL_APPLY_PROM_DE
Current String Value is Apply Promotion Defaults Translate Flag is TRUE Type is Conversion Project is Symbolic String
- Name is SBL_LOG_HDLS_ERR
Current String Value is Log Error Translate Flag is TRUE Type is Conversion Project is Symbolic String
- Import the archived files. Archived (.sif) files are located in the ACR471.zip file located in the Siebel Tools Installation Directory
\REPPATCH folder.
- Import the CSSHeadlessCfgService Class:
- Import the Headless Configuration Service business service:
- Import the ISS Promotion Management Service business service:
- Import the UMF Message List SI applet:
- Import workflow processes:
NOTE: Workflow (.xml) files are located in the ACR471.zip file located in the Siebel Tools Installation Directory\REPPATCH folder.
- Navigate to Workflow Process in the Object Explorer.
- Import workflow files as follows:
- Set up the Business Component:
- Navigate to Business Component in the Object Explorer.
- Search for the business component ISS Promotion Item Attribute Value.
- Set the value of Sort Specification to Created.
- Compile the following locked projects into an srf file:
- Headless Configuration
- Symbolic Strings
- UMSUI
- Unlock all projects.
- Close Siebel Tools.
