Siebel Order Management Guide Addendum for Communications > Employee Asset-Based Ordering > Defining Product Promotions >
Configuring the Pricing Signal Name for In Memory Promotion Upgrade Process Workflow
By default, the In Memory Upgrade Promotion Process workflow triggers the CalculatePrice signal to call the Dynamic Pricing Workflow. However, using the In Memory Promotion Upgrade Process, administrators can configure the Pricing Signal Name to call a custom signal to calculate prices. Administrators can change the Pricing Signal name by passing a custom signal name as a value to the PricingSignal input property to the Call Pricer step of the In Memory Promotion Upgrade Process workflow. To configure the pricing signal name for the In Memory Promotion Upgrade Process workflow
- Open Siebel Tools.
- Navigate to the Object Explorer, then the Workflow Process.
- Query for the following workflow:
- From the View menu, under Toolbars, select the WF/Task Editor Toolbar.
- Click the Revise icon on the WF/Task Editor Toolbar.
- Right-click on Edit Workflow Process.
- Go to the Call Pricer step and add inputArgs with the following specifications:
PricingSignal |
Literal |
CustomPricingSignal |
- Publish or Activate the In Memory Promotion Upgrade Process workflow.
