Siebel Order Management Guide Addendum for Communications > Employee Asset-Based Ordering > About Dynamic TransformSiebel Order Management for Industry Applications allows users to dynamically transform promotion components without a product administrator having to explicitly define all split and merge paths between promotions. This feature enables users to dynamically split and dynamically merge existing bundled promotion assets without any pre-defined scenario, provided that an upgrade path exists between the source and target promotions. By eliminating the need to define split and merge transitions, the dynamic transform feature can reduce the time-to-market of new offerings. For a given account, users can use the dynamic transform feature to do the following:
You can access the dynamic transform feature contextually when viewing installed assets for an account. For more information about the dynamic transform feature, see Performing a Promotion Dynamic Transform. |
| Siebel Order Management Guide Addendum for Communications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
