Siebel Order Management Guide Addendum for Communications > Employee Asset-Based Ordering > Configuring the Edit Promotion Product SelectionThe behavior described in this topic applies to components of a bundled promotion that are defined as aggregates. When a user selects a promotion in the Sales Order screen, Line Items view, then clicks the Line Items list Menu button and chooses Edit Promotion, your Siebel application displays a view in which you can edit the promotion. In this Edit Promotion view, by default, users can select nonprimary product line products. However, queries involving nonprimary product lines can adversely affect performance for product lines that involve large quantities of data. You therefore have the option of disabling this behavior. To disable Edit Promotion product selection, follow this procedure. To disable Edit Promotion product selection
For more information about changing user property values, see Using Siebel Tools. |
| Siebel Order Management Guide Addendum for Communications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
