Siebel Order Management Guide Addendum for Communications > Employee Asset-Based Ordering > About Bundling Components for a Promotion >
Example of Bundling Components for a Promotion
This topic gives one example of bundling components for a promotion. You might use this feature differently, depending on your business model. To bundle components for a promotion
- Navigate to the Billing Items view, or the Installed Assets view, or the Quote Item, or the Order Item view.
- Select Menu and then Add to Promotion.
- In the Pick Promotion dialog box, select the promotion to add.
NOTE: The OK button is disabled if the selected record is ineligible. The record is ineligible if it violates the maximum cardinality of the promotion component, which is computed by adding the projected asset cache for the component with the quantity.
