Siebel Order Management Guide Addendum for Communications > Employee Asset-Based Ordering > Configuring the Projected Asset Cache Search Specification >
About Business Service and Workflow Configurations
The following rules apply to both the new business service user properties and the additional workflow input arguments:
- Any field that is added in the search specification must be present in both the Asset Mgmt - Asset and Asset Mgmt - Asset XA business components.
- Any field that is added in the search specification must be present in both the Order Entry - Line Items and Order Item XA business components.
- Any field that is added in the search specification must be present in both the Quote Item and Quote Item XA business components.
User property and workflow changes are optional. If these changes are present, then they are appended. Otherwise, they are ignored.
