Siebel Order Management Guide Addendum for Communications > Employee Asset-Based Ordering > About Promotion Transitions Ambiguity Resolution > Removing a Promotion Component from the Target Promotion DefinitionThis topic describes how to send component instances back to the pool of ambiguous components using the Remove button. The Remove button allows users to remove a promotion component after it has been transferred while resolving an ambiguous promotion transition. These instructions presume that an ambiguity has been detected, and the user has been presented with the dialog box to resolve the ambiguity. To remove a promotion component from the target promotion definition
Siebel Order Management Guide Addendum for Communications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
