Siebel Order Management Guide Addendum for Communications > Employee Asset-Based Ordering > Process of Setting Up Time-Based Offerings >
Adding a Time-Based Offering Discount to a Bundled Promotion (Administrator)
To add a time-based offering discount product to a bundled promotion, follow this procedure. For more information about setting up bundled promotions, see the chapter on creating product promotions in Siebel Pricing Administration Guide. This task is a step in Process of Setting Up Time-Based Offerings. To add a time-based offering discount to a bundled promotion
- Navigate to Administration - Product, then the Product Promotions view.
- In the Product Promotions list, create a new record and select Bundled Promotions in the Type field.
- Complete the other fields, as required.
- Click the Products view tab under the Product Promotions list, then the Components link.
- In the Components list, add a new record.
- In the Product Name field, select a time-based offering discount product, and complete the other fields as needed.
- Define the attributes for the discount component product by performing the following steps.
- Click the link in the Product Name field.
The Promotion subview appears.
- Click the Attributes link.
- In the Attributes list, create and define new product attribute records as shown in the following table.
Duration |
Include |
DurationUnitOfMeasure |
Include |
DurationValidityStart |
Include |
- Define the duration and start date of the promotion by selecting each attribute record in turn and adding a value in the Values list below the Attributes list, as shown in the following table.
Duration |
Numeric value for the duration of the offer. Select a number from 1 to 31. |
Unit of measure for the duration of the offer. Select Days, Months, or Years. |
Beginning point for the duration of the offer. Select one of the following values:
- Continue adding component products to the bundled promotion product, as needed.
The terms defined in the time-based discount component product will apply to the bundled promotion product of which the time-based offering is a component.
