Siebel Order Management Guide Addendum for Communications > Employee Asset-Based Ordering > Roadmap for Configuring Bulk Requests >
Setting Up Bulk Requests on a Mobile Web Client
Some configuration is required for running Bulk Requests on Oracle's Siebel Mobile Web Client. NOTE: Bulk requests run in synchronous mode when performed from Oracle's Siebel Mobile Web Client.
This task is a step in Roadmap for Configuring Bulk Requests. To set up Bulk Requests on a Mobile Web Client
- Start Siebel Tools.
- Query for the ABO Bulk Request Header business component and search for the Named Method 5 user property.
- In the business component, change the value of the Named Method 5 user property to the following value.
"Submit", "INVOKESVC", "ABO Bulk Request Header", "Workflow Process Manager", "RunProcess", "'ProcessName'", "'ABO Bulk Request - Submit Process Workflow'", "'Bulk Request Id'", "[Id]", "'Mode'", "[Mode]"
You can copy this value from the Comments of the user property.
- Query for the ABO Bulk Request - Submit Process Workflow and search for the Parallel Process Flag.
- In the workflow, set the Parallel Process Flag to N, if this flag has not been set already.
- Query for the ABO Bulk Request - Explode Driver Workflow and search for the Asyn Flag.
- In the workflow, set the Asyn Flag to N, if this flag has not been set already.
- Compile the SRF file used by your Siebel application.
For more information about changing the values of objects in Siebel Tools, see the chapter on working with objects in Using Siebel Tools.
- If Asset-Based Ordering has not been enabled, then enable this functionality by performing the following steps.
- Open the uagent.cfg/scomm.cfg file.
- In the [InfraObjMgr] section of the file, set the following value:
AssetBasedOrderingEnabled = TRUE
- Save and close the scomm.cfg file.
- Restart your Siebel application.
