Siebel Order Management Guide Addendum for Communications > Employee Asset-Based Ordering > About Synchronizing Product Attributes, Product Classes, Products, and Promotions > About Synchronizing ProductsYou can synchronize simple products with one price type and simple products with multiple price types through the integration. A simple product with, for example, two price types in Oracle Product Information Management Data Hub becomes two products in Siebel CRM. You can also synchronize complex products, that is, customizable products, through the integration. The parameters of a product in Oracle Product Information Management Data Hub that are synchronized with Siebel CRM are as follows:
The integration does not support the synchronization of eligibility rules, or of collateral items such as image files and key features. Additionally, synchronization does not override certain product parameters. These parameters include user interface setup, configurator rules, and scripts defined in Siebel CRM. These parameters must be entered and maintained in Siebel CRM. Most fields that are synchronized are visible in the Administration - Product screen, Detail view and the Administration - Product screen, Product Definitions view. NOTE: The Domain Type field value of Dynamic Class is not supported by the integration. |
| Siebel Order Management Guide Addendum for Communications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
