Siebel Order Management Guide Addendum for Communications > Using Network Ordering > Process of Upgrading Bandwidth at Network Sites > Converting a Completed Order to Upgrade Bandwidth to AssetsAs components to upgrade bandwidth are installed, convert the line items representing these components to assets so that you can track these assets for service and change orders. For more information about converting orders to assets, see the topic about the workflow that applies an order to the service profile in Siebel Order Management Guide. For more information about assets, see Siebel Field Service Guide. NOTE: Before configuration, you can use the Auto Asset button to convert line items to assets. However, during configuration, the Auto Asset button is usually removed, and the process is automated. If the Auto Asset button is available, then use the following procedure. This task is a step in Process of Upgrading Bandwidth at Network Sites. To convert a line item representing a network component to an asset |
| Siebel Order Management Guide Addendum for Communications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
