Siebel Order Management Guide Addendum for Communications > Using Network Ordering > Process of Disconnecting a Site from a Network > Updating Assets After Network Site DisconnectionWhen the work to disconnect each component at a network site is complete, update the customer assets so that these assets no longer include the component. For more information about converting orders to assets, see the topic about the workflow that applies an order to the service profile in Siebel Order Management Guide. NOTE: Before configuration, you can use the Auto Asset button to convert line items to assets. However, during configuration, the Auto Asset button is usually removed, and the process is automated. If the Auto Asset button is available, then use the following procedure. This task is a step in Process of Disconnecting a Site from a Network. |
| Siebel Order Management Guide Addendum for Communications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
